show access-list usage acl-rule port
show access-list usage acl-rule port port
Description
Displays the number of ACL rules consumed by the ACLs on a particular port or on the slices that support a particular port.
Syntax Description
port Specifies to display the usage on this port.
Default
N/A.
Usage Guidelines
Use this command to display the rules used per slice, and also display the rule usage of the specified port.
The following example displays the ACL rule usage on port 5:
Switch.3 # show access-list usage acl-rule port 5
Ports 1-12, 25-36
Total Rules:     Used: 34  Available: 990
In ExtremeXOS 15.5.1 and onwards, unless there is at least 1 rule in a given slice, the slice is not allocated. Since the slice is not yet allocated, a physical slice is not assigned to a virtual slice. So in this previous example, "used" displays what is used in that particular slice, and "available" shows the remaining rules in that particular used slice.
The following example displays the ACL ingress and egress rule usage on port 5:1:
Switch.4 # show access-list usage acl-rule port 5:1
Ports 5:1-5:48
Total Ingress/Egress Rules:
Used: 11  Available: 8181
Used: 1  Available: 1023
This command was first available in ExtremeXOS 11.4.
Platform Availability
